Hello
I've successfully set up geoportal 1.2.2 using Tomcat 7 and PostgreSQL 9.1.
My company's proxy server, however, seems to be blocking the geoportals communication with the iternet.
When I try registering a resource I get an 'Unable to connect to the host' message.
Also when I try searching the default ArcGIS Online resources I get the following error:
Unable to load /geoportal/rest/find/document?rid=arcgis.com&ridName=ArcGIS.com&rids=arcgis.com&start=1&max=10&maxSearchTimeMilliSec=10000&f=searchpageresults&dojo.preventCache=1364948523707 status:500/geoportal/rest/find/document?rid=arcgis.com&ridName=ArcGIS.com&rids=arcgis.com&start=1&max=10&maxSearchTimeMilliSec=10000&f=searchpageresults
If I use a direct internet connection i.e no proxy, everything works fine.
So I was wondering if someone could tell me which ports Geoportal uses?
