I am looking to use an Update Cursor over a feature layer in a map document to, well, update a handful of attributes. I seem to be getting an error that tells me the instance of my object does not have the attribute of the cursor's name...Here is the problem code:class Intersections(): def __init__(self): self.path = arcpy.GetParameterAsText(1) def updateAttributes(self): self.intersections = arcpy.UpdateCursor(self.path) self.centerlines = Centerlines() arcpy.AddMessage("Updating node attributes...") try: for self.intersection in self.intersections: #THIS IS WHERE IT FAILS
The error reads: Intersections instance has no attribute 'intersection'Oddly enough, in the same script, I have this code that does work properly:def __init__(self): self.path = arcpy.GetParameterAsText(2) def copyAttributes(self): self.addressRanges = arcpy.InsertCursor(self.path) self.centerline = Centerlines() self.centerlines = arcpy.SearchCursor(self.centerline.path) arcpy.AddMessage("Copying new address ranges...") try: for self.centerline in self.centerlines:
ThanksEDIT: I was able to pinpoint the error, which was happening lower in the code. I was trying to delete the cursors, which did not exist at that point.
