frmap1
How to use the NEAR Class: the basics ?
Discussion created by frmap1 on Mar 30, 2013
Latest reply on Mar 31, 2013 by mbaird-esristaff
(This post was sent in the geoprocessing forum, but I moved it here)
I'm using the Java SDK in Eclipse.
I want to determine the distance between a point (in a first shapefile) and the nearest point amongs a set of many points (in a second shapefile).
For this purpose, I use the Near Class, but my simple code contain an error (see below). The shapefiles that I use have successfully been used in the Buffer Class in another code, so it seems that I dont use the NEAR class correctly.
I would appreciate if you could explain how the NEAR class should be used.
I'm using these lines of code:
//// Java code begins here
// Create a Near object, with both input shapefiles in the constructor
Near near = new Near("D:\\myPosition.shp","D:\\myManyPositions.shp");
// Create a geoprocessor and execute the Near object
GeoProcessor gp = new GeoProcessor();
IGeoProcessorResult result1 = gp.execute(near, null);
//// Java code ends here
Outcomes
