How to find the difference between two polygons
6070
03-27-2013 11:21 AM
JoseSanchez
Occasional Contributor III
Hi all
In order to find what has added or remoed form a polygon I am comparing two different version of the same polygon.
How can I find the portions that were added or deleted?
What geoprocessing tool can I use?
MelanieSummers
Hi Jose,
Take a look at the Feature Compare tool.
Best,
Melanie S.
DanLee
by Esri Regular Contributor
Jose,
A change to a polygon could mean many things. The Intersect tool can give you what's in common. You can also explore the other Analysis - Overlay tools.
What are the features that you are dealing with, parcels, buildings, or else?  Is it possible that you share some sample data?
