I modified one line and added two in the createMap function in layout.js. It looks like it accomplishes setting a custom extent and adding a ArcGISDynamicMapServiceLayer in the 3.4 Basic Viewer template. Is this the right approach? function createMap(webmapitem) {
var mapDeferred = esri.arcgis.utils.createMap(webmapitem, "map", {
mapOptions: {
slider: configOptions.displaySlider,
sliderStyle: 'small',
wrapAround180: !configOptions.constrainmapextent,
showAttribution: true,
//set wraparound to false if the extent is limited.
logo: !configOptions.customlogo.image //hide esri logo if custom logo is provided
ignorePopups: false,
bingMapsKey: configOptions.bingmapskey
mapDeferred.addCallback(function (response) {
//add webmap's description to details panel
if (configOptions.description === "") {
if (response.itemInfo.item.description !== null) {
configOptions.description = response.itemInfo.item.description;
//initialExtent = response.map.extent;
initialExtent = new esri.geometry.Extent({"xmin":-12345,"ymin":12345,"xmax":-12345,"ymax":12345,"spatialReference":{"wkid":102100}});
if (configOptions.extent) {
var extent = new esri.geometry.Extent(dojo.fromJson(configOptions.extent));
initialExtent = extent;
configOptions.owner = response.itemInfo.item.owner;
document.title = configOptions.title || response.itemInfo.item.title;
//add a title
if (configOptions.displaytitle === "true" || configOptions.displaytitle === true) {
configOptions.title = configOptions.title || response.itemInfo.item.title;
dojo.create("p", {
innerHTML: configOptions.title
}, "header");
dojo.style(dojo.byId("header"), "height", "38px");
} else if (!configOptions.link1.url && !configOptions.link2.url) {
//no title or links - hide header
esri.hide(dojo.byId('header'));
dojo.addClass(dojo.body(), 'embed');
dojo.query("html").addClass("embed");
//get the popup click handler so we can disable it when measure tool is active
clickHandler = response.clickEventHandle;
clickListener = response.clickEventListener;
map = response.map;
//Constrain the extent of the map to the webmap's initial extent
if (configOptions.constrainmapextent) {
webmapExtent = response.map.extent.expand(1.5);
if (map.loaded) {
initUI(response);
} else {
dojo.connect(map, "onLoad", function () {
initUI(response);
map.setExtent(initialExtent);
var MapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://mywebsite.com/arcgis/rest/services/Blah/MapServer");
map.addLayer(MapServiceLayer);
mapDeferred.addErrback(function (error) {
alert(i18n.viewer.errors.createMap + " : " + dojo.toJson(error.message));
