Operation dashboard unstable with query layer as stand-alone datasource
3027
03-18-2013 06:43 PM
JackZHANG
Occasional Contributor II
I publish a map service which has a feature class layer, and a query layer building from a feature class joined with a table (all in the same SDE).
When I added the layers into Dashboard as stand-alone datasource, I notice the feature class layer works fine for most time, but not the query layer. I can add the query layer as datasource with no issue, and sometimes I can build from it a widget (bar char, half-donut etc.) with the default settings. But once I start config the widget, the query layer connect gets broken on the REST point the map service I can see it's working fine. I tried it on different computers on different network to eliminate it's not caused by network connection.
Wondering if anyone aware of the issue or similars?
