ncarter-esriuk-esridist
Unable to publish Geocoding service: 'Unable to connect to publishing tool service"
Discussion created by ncarter-esriuk-esridist on Mar 15, 2013
Latest reply on Jun 27, 2013 by seesee
Hi all
I am trying to publish a geocoding service from a locator in ArcCatalog 10.1 SP1 using the 'Share As -> Geocoding Service' method. When I do this I go through the process and at the last I receive an error stating 'Failed to Publish Service'. When I look at the GeoProc results I see an error stating 'ERROR: unable to connect to publishing service tools service. Verify the service is up and running'
I created a simple map and used the same method to successfully create a map service and so I think that the problem is just with publishing locators as geocoding servives.
Any clues?
Niall Carter
Outcomes
