LisaArn
Secured services not visible in services directory
Discussion created by LisaArn on Mar 8, 2013
Latest reply on Mar 13, 2013 by LisaArn
I have created an application using the Flex application builder. I am now trying to get things set up so the application can access secured services. I have set up a User and Role using the ArcGIS Server built-in store.  I then secured the two services which will be used in the application via ArcGIS Server Manager. My plan now is to implement access by including the token in the map request by setting the token property of the service in the config.xml file. However, when I login to the Services Directory page with the user I created, the secured services are not visible. Other non-secured services are visible, but not the secured ones I need to generate a token for. What could be the reason these secured services are not visible?
Outcomes
