ERROR 030060 : could not find network
1249
03-07-2013 03:50 AM
RandallBrown1
We have a consultant starting to do some specialty work and I took my working directory and copied it to the new desktop for the consultant.  Everything works the same exept for a couple of tools I created using model builder.  These tools work fine on my machine but not this new desktop.  I can use NETWORK ANALYST manually and create the service area I want but when I try to do the same with the model tool it gives me this error for the street network dataset.
Meters" NO_LINES_SOURCE_FIELDS NO_HIERARCHY #
Start Time: Thu Mar 07 06:39:31 2013
ERROR 030060: Could not open network C:\ISRB_PCC\Project\StreetMap_Data_10_2012-07-07\StreetMap_Data\streets.
Failed to execute (Make Service Area Layer).
Failed at Thu Mar 07 06:39:31 2013 (Elapsed Time: 0.00 seconds)
Failed to execute
Where I can run network analyst manually without a problem using this same network dataset, I am not sure why this error. If anyone has a suggestion I would appreciate it.
thanks in advance.
