humzarr
can only add webmaps using portal explorer?
Discussion created by humzarr on Mar 6, 2013
Latest reply on Mar 28, 2013 by njarecha-esristaff
Does the esri portal explorer allows to add feature services or tiled map services on your current open base map on your custom app? becasue the arcgis app for ios only allows you to add webmaps with your layer hosted on the webmap.
Outcomes
