cbusto
Question regarding populating a field in model builder with either Python or VB
Discussion created by cbusto on Mar 5, 2013
Latest reply on Mar 6, 2013 by LDanzinger-esristaff
I'm looking to populate a field using the calculate tool in model builder. To populate the column within my table I want to use a series of if, then statements so the model accurately assigns the correct value to its respective column.  I'm trying to populate the TP_Load_lbs column with the appropriate loading values based on the previously populated values from four separate columns: landuse= Industrial, Commercial and gridcode = 0 or 1, and soil A B C or D, Area.  I've been trying to use the code below, but I continue to get an error message. Should I be entering this code in the expression line or the code block.
For example:
if [LU] == "Industrial" and [grid_code] == 1:
[TP_Load_lbs] = 1.8 * [Area]
elif [LU] == "Industrial" and [grid_code] == 0 and  [Soil] == "A" or "B":
  [TP_Load_lbs] = 0.2 * [Area]
elif [LU] == "Industrial" and [grid_code] == 0 and  [Soil] == "C":
  [TP_Load_lbs] = 0.4 * [Area]
elif [LU] == "Industrial" and [grid_code] == 0 and  [Soil] == "D":
  [TP_Load_lbs] = 0.7 * [Area]
elif [LU] == "Commercial" and [grid_code] == 1:
  [TP_Load_lbs] = 1.9 * [Area]
elif [LU] == "Commercial" and [grid_code] == 0 and  [Soil] == "A" or "B":
  [Load_lbs] = 0.3 * [Area]
elif [LU] == "Commercial" and [grid_code] == 0 and  [Soil] == "C":
  [TP_Load_lbs] = 0.5 * [Area]
elif [LU] == "Commercial" and [grid_code] == 0 and  [Soil] == "D":
  [TP_Load_lbs] = 0.8 * [Area]
Any help would be gladly appreciated, especially regarding the accuracy of my code to achieve my intended goal.
Natalie
Outcomes
