I've been porting code to the newest version of the api (10.1). It seems that geometryEngine shapePreservingAreaOfGeometry has changed in some way that throws an EXEC_BAD_ACCESS(code=2, address=0xf) error. This is both in my code and in the GeometrySample project I downloaded from the examples. Can anyone else confirm this so I can rule out my local installation of the api? If anyone else is seeing this, have you found a workaround?
Will
