I am using ArcSDE 10.1 and PostgreSQL 9.1/PostGIS 2.0. I have backups of a production database that I'd like to use for a development database. The name of the development database appends "_dev" to the database name to avoid confusion. However, when I restore the production backup to the development database, I receive the following error on connection:
Which leads me to believe that one or more functions in the sde schema is defined with database names as a reference and restoring to a database with a different name doesn't work.
I have also tried creating the enterprise geodatabase first and then restoring a backup of the production database that excludes the 'sde' schema. The connection works, but now my 800+ feature classes are not registered with the geodatabase.
Are there any best practices published for working with production and development databases that might help me here?
Thanks.
2013-03-05 08:07:28 PST ERROR: cross-database references are not implemented: "cvag.sde.sde_object_ids" at character 21 2013-03-05 08:07:28 PST QUERY: SELECT base_id FROM cvag.sde.sde_object_ids WHERE id_type = i_id_type FOR UPDATE 2013-03-05 08:07:28 PST CONTEXT: PL/pgSQL function "sde_get_primary_oid" line 15 at FOR over SELECT rows 2013-03-05 08:07:28 PST STATEMENT: SELECT cvag_dev.sde.SDE_get_primary_oid ($1,$2)
Thanks.
