I've been doing a some work with the System Designer tool and I was wondering if it's possible to map a workflow to more than one application. For example I have a workflow that draws an image from an image service. I would like to use this workflow in several applications. As near as I can tell it appears you only map one workflow to one one application indicating the workflow would have to be copied and renamed for each application I would to use it in. Is my assumption correct?
Cheers!
