amahedy
TopoToRaster Boundary - ArcMap Crash
Discussion created by amahedy on Mar 4, 2013
Latest reply on Mar 15, 2013 by amahedy
I'm trying to perform a TopoToRaster interpolation of bathymetric data that falls within a given boundary defined by the stream. I added the point shapefile and specified the Type as "Point Elevation" and the Field of interest. I then added the boundary polygon shapefile and specified the type as "Boundary". Output cell size was set to 30 m and the output extent was set to the same file as the boundary polygon shapefile. The primary type of input data was set to "Spot". Everything else was left as a default value. When I run this interpolation, ArcMap always crashes. No error message is given. Anyone have an idea of what is going on?
Outcomes
