var app = {}; app.map = null; var legendLayers = []; var clickHandler; function init() { //add popup var popup = new esri.dijit.Popup({ fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255,0,0]), 2), new dojo.Color([255,255,0,0.25])) }, dojo.create("div")); //add geometry service esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://server/rest/services/Utilities/Geometry/GeometryServer"); //initalize map app.map = new esri.Map("map", { basemap : "streets", center : [-111.924531, 40.611871], zoom : 13, infoWindow: popup }); //add parcel layer var parcels = new esri.layers.ArcGISDynamicMapServiceLayer("http://server/arcgis/rest/services/Parcels_UT/MapServer", { id : 'parcels', visible : false }); legendLayers.push({ layer : parcels, title : 'Parcels' }); //add parcel query data var content = "<b>Address</b>: ${ADDR}" + "<br /><b>Owner Name</b>: ${OWNER}" + "<br /><b>Parcel ID</b>: ${APN}" + "<br /><b>City</b>: ${CITY}" + "<br /><b>Acres</b>: ${TOTAL_ACRE}" + " <br /><a href='${COUNTY_LIN}'>County Assessor Site</a>" var popUpTemplate = new esri.InfoTemplate("Parcel", content); //add paercel layer as feature layer var featureLayer = new esri.layers.FeatureLayer("http://server/arcgis/rest/services/Parcels_UT/MapServer/0",{ mode: esri.layers.FeatureLayer.MODE_SELECTION, outFields: ["*"], infoTemplate:popUpTemplate }); //create legend dojo.connect(app.map, 'onLayersAddResult', function(results) { var legend = new esri.dijit.Legend({ map : app.map, layerInfos : legendLayers }, "legendDiv"); legend.startup(); }); app.map.addLayers([parcels]); dojo.connect(app.map, 'onLayersAddResult', function(results) { //add legend check boxes dojo.forEach(legendLayers, function(layer) { var layerName = layer.title; var checkBox = new dijit.form.CheckBox({ name : "checkBox" + layer.layer.id, value : layer.layer.id, checked : layer.layer.visible, onChange : function(evt) { var clayer = app.map.getLayer(this.value); clayer.setVisibility(!clayer.visible); this.checked = clayer.visible; //toggle the feature layer with the parcel layer if (this.value ==="parcels" && this.checked === true){ clickConnect(true); console.log("parcels"); } else if (this.value ==="parcels"){ clickConnect(false); console.log("noParcels"); } } }); //add the check box and label to the table of contnents dojo.place(checkBox.domNode, dojo.byId("toggle"), "after"); var checkLabel = dojo.create('label', { 'for' : checkBox.name, innerHTML : layerName }, checkBox.domNode, "after"); dojo.place("<br />", checkLabel, "after"); }); }); dojo.connect(app.map, 'onLoad', function(map) { initToolbar(app.map); }); function executeIdentifyTask(evt) { var query = new esri.tasks.Query(); query.geometry = pointToExtent(app.map,evt.mapPoint,10); var deferred = featureLayer.selectFeatures(query,esri.layers.FeatureLayer.SELECTION_NEW); app.map.infoWindow.setFeatures([deferred]); app.map.infoWindow.show(evt.mapPoint); } function clickConnect(connect){ if(connect){ //perform the identify task on click clickHandler = dojo.connect(app.map, "onClick", executeIdentifyTask); }else{ //disconnect the click handler dojo.disconnect(clickHandler); clickHandler = null; } } } function initToolbar(mymap) { //define a new line symbol and point symbol to use for measure tools var pms = new esri.symbol.PictureMarkerSymbol("images/flag.png", 24, 24); pms.setOffset(9, 11); var sls = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_DOT, new dojo.Color([255, 0, 0, .55]), 4); var measurement = new esri.dijit.Measurement({ map : mymap, lineSymbol : sls, pointSymbol : pms }, dojo.byId('measurementDiv')); measurement.startup(); measurement.setTool("area", false); } function pointToExtent(map, point, toleranceInPixel) { var pixelWidth = map.extent.getWidth() / map.width; var toleraceInMapCoords = toleranceInPixel * pixelWidth; return new esri.geometry.Extent( point.x - toleraceInMapCoords, point.y - toleraceInMapCoords, point.x + toleraceInMapCoords, point.y + toleraceInMapCoords, map.spatialReference ); } dojo.ready(init);
Solved! Go to Solution.
dojo.connect(measurement.area, "onClick", function(){ if (this.checked) { console.log("I'm checked"); dojo.disconnect(yourClickHandler); } });
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN" "http://www.w3.org/TR/html4/strict.dtd"> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"/> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" /> <!-- // The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices --> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/> <!-- // include a title for the window tab name --> <title>Multiple Service Layer Identify Popup InfoWindow</title> <!-- // define the location of the JavaScript API version 3.1 --> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/dojo/dijit/themes/soria/soria.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.1/js/esri/dijit/css/Popup.css"> <style type="text/css"> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } </style> <script type="text/javascript"> var djConfig = { parseOnLoad: true }; </script> <script type="text/javascript" src="http://serverapi.arcgisonline.com/jsapi/arcgis/?v=3.1"></script> <script type="text/javascript" language="Javascript"> dojo.require("esri.map"); dojo.require("esri.dijit.Measurement"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.dijit.Popup"); dojo.require("dojo.DeferredList"); dojo.require("esri.arcgis.utils"); dojo.require("esri.layers.FeatureLayer"); var identifyParams; var tasks; var clickPoint; var connection; var checked; var map; function init() { var popup = new esri.dijit.Popup({ fillSymbol: new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 2), new dojo.Color([255, 255, 0, 0.25]))}, dojo.create("div")); var initialExtent = new esri.geometry.Extent({"xmin":-9549173.347091435,"ymin":4614123.468713058,"xmax":-9546388.17287322,"ymax":4615432.452822477,"spatialReference":{"wkid":102100}}); map = new esri.Map("map", { extent: initialExtent, infoWindow: popup }); dojo.place(popup.domNode, map.root); dojo.connect(map,'onLoad',function(){ //setup generic identify parameters identifyParams = new esri.tasks.IdentifyParameters(); identifyParams.tolerance = 10; identifyParams.returnGeometry = true; identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL; dojo.connect(map,'onClick',doIdentify); }); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"); map.addLayer(basemap); var dynlayer1 = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyFeedSample/MapServer",{opacity:.50}); var dynlayer2 = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyHazardsandRisks/MapServer",{opacity:.50}); var dynlayer3 = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/PublicSafety/PublicSafetyOperationalLayers/MapServer"); var measurement = new esri.dijit.Measurement({ map: map }, dojo.byId('measurementDiv')); measurement.startup(); dojo.connect(measurement.area, "onClick", function(){ //change the value as you click on the tool if (this.checked) { checked=true; } else checked=false; }); dojo.connect(measurement.distance, "onClick", function(){ if (this.checked) { checked=true; } else checked=false; }); dojo.connect(map,'onLayersAddResult', setupIdentify); map.addLayers([dynlayer3,dynlayer2,dynlayer1]); } function setupIdentify(results){ //loop through operational layers and add identify task for each. tasks = dojo.map(results,function(result){ return new esri.tasks.IdentifyTask(result.layer.url); }); } function doIdentify(evt){ // only do the identify when the tool is not used if (checked!=true) { map.infoWindow.hide(); clickPoint = evt.mapPoint; identifyParams.geometry = evt.mapPoint; identifyParams.mapExtent = map.extent; identifyParams.width = map.width; identifyParams.height = map.height; var deferreds = dojo.map(tasks,function(task){ return task.execute(identifyParams); }); var dlist = new dojo.DeferredList(deferreds); dlist.then(handleQueryResults); } } function handleQueryResults(results){ var features = []; dojo.forEach(results,function(result){ // for a simplified test let's just display all the attributes in the popup if(result[1].length > 0){ dojo.forEach(result[1],function(r){ var feature = r.feature; console.log(feature); feature.attributes.layerName =r.layerName; var infoTemplate = new esri.InfoTemplate('Attributes', "${*}"); feature.setInfoTemplate(infoTemplate); features.push(feature); }); } }); map.infoWindow.setFeatures(features); map.infoWindow.show(clickPoint); } dojo.addOnLoad(init); </script> </head> <body class="soria"> <div id="mainWindow" dojotype="dijit.layout.BorderContainer" design="headline" gutters="false" style="width:100%; height:100%;"> <div id="map" class="shadow" dojotype="dijit.layout.ContentPane" region="center" > <div style="position:absolute; right:20px; top:10px; z-Index:999;"> <div id="titlePane" data-dojo-type="dijit.TitlePane" data-dojo-props="title:'Measurement', closable:'false', open:'false'"> <div id="measurementDiv"></div> <span style="font-size:smaller;padding:5px 5px;">Press <b>CTRL</b> to enable snapping.</span> </div> </div> </div> </div> </div> </body> </html>
var measurement; ready(function(){ parser.parse(); //Create a map var map = new Map("map", { center: [-112.0000, 34.0000], zoom: 7, basemap: "topo" }); measurement = new Measurement({ map: map }, dom.byId("measureDiv")); measurement.startup(); //set the popup's popupWindow property to false. This prevents the popup from displaying map.infoWindow.set("popupWindow", false); initializeSidebar(map); // Create info Template var template = new InfoTemplate(); template.setContent("<b>Counties info:</b><br/>" + "County Name: <b>${NAME}</b><br/>"+ "Reimbursment 1: <b>${Reim1}</b><br/>" + "Reimbursment 2: <b>${Reim2}</b><br/>" + "Reimbursment 3: <b>${Reim3}</b><br/>" + "Reimbursment 4: <b>${Reim4}</b><br/>" + "<hr>"+ "<b>Game Management Units Info:</b><br/>" + "GMU: <b>${GMU}</b><br/>"+ "Region Name: <b>${REG_NAME}</b><br/>" + "Landown: <b>${LANDOWN}</b><br/>" + "Hunt: <b>${HUNT}</b><br/>"); //add features to map var Outside = new FeatureLayer("URL",{ mode: FeatureLayer.MODE_ONDEMAND, infoTemplate: template, outFields: ["NAME"] }); var Counties = new FeatureLayer("URL",{ mode: FeatureLayer.MODE_ONDEMAND, infoTemplate: template, outFields: ["NAME", "Reim1", "Reim2", "Reim3", "Reim4"] }); var GMUs = new FeatureLayer("URL", { mode: FeatureLayer.MODE_ONDEMAND, infoTemplate: template, outFields:["GMU", "REG_NAME", "LANDOWN", "HUNT"] }); var Travel = new FeatureLayer("URL", { mode: FeatureLayer.MODE_ONDEMAND, outFields:["*"] }); map.addLayers([Outside,Counties,GMUs,Travel]); }); function initializeSidebar(map){ var popup = map.infoWindow; //when the selection changes update the side panel to display the popup info for the //currently selected feature. connect.connect(popup, "onSelectionChange", function(){ displayPopupContent(popup.getSelectedFeature()); }); //when the selection is cleared remove the popup content from the side panel. connect.connect(popup, "onClearFeatures", function(){ //dom.byId replaces dojo.byId dom.byId("featureCount").innerHTML = "Click to select feature(s)"; //registry.byId replaces dijit.byId registry.byId("leftPane").set("content", ""); domUtils.hide(dom.byId("pager")); }); //When features are associated with the map's info window update the sidebar with the new content. connect.connect(popup, "onSetFeatures", function(){ displayPopupContent(popup.getSelectedFeature()); dom.byId("featureCount").innerHTML = popup.features.length + " feature(s) selected"; //enable navigation if more than one feature is selected popup.features.length > 1 ? domUtils.show(dom.byId("pager")) : domUtils.hide(dom.byId("pager")); }); } function displayPopupContent(feature){ if(feature){ var content = feature.getContent(); registry.byId("leftPane").set("content", content); } } on(dojo.byId("clearAll"), "click", clearmeas); function clearmeas(){ measurement.clearResult(); } }); </script> </head> <body class="claro"> <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width:100%; height:100%;"> <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="gutters:false" region="left" style="width: 20%;height:100%;"> <div id="leftPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div> <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'"> <div id="featureCount" style="margin-bottom:5px;">Click on feature(s) to select</div> <!--<input type="text" id="capacity" value="4" /> <input type="button" value="Get Details" onclick="executeQueryTask(dojo.byId('capacity').value);" />--> <div id="pager" style="display:none;"> <a href='javascript:void(0);' id ="previous" class='nav' style="text-decoration: none;"> < Prev </a> <a href='javascript:void(0);' id="next" class='nav' style="text-decoration: none;"> Next > </a> </div> </div> </div> <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"> <div id="search"></div> <div id="HomeButton"></div> <div id="BasemapToggle"></div> <div style="position:absolute; right:20px; top:20px; z-Index:999;"> <div id="titlePane" data-dojo-type="dijit.TitlePane" data-dojo-props="title:'Measurement Tool', open: false"> <span style="font-size:smaller;padding: 20px;">Select the Area or Distance measurement</br> tool then click the map to start measuring.</br> Double click to finish measuring.</span> <div id="measureDiv"></div><hr><button id="clearAll" type="button">Clear Measure</button> </div> </div> </div> </div> </body> </html>
