Solved! Go to Solution.
#Purpose: Compares SheeID field to the toal PDFs created from Data Driven Pages Program import arcpy, os, sys #Make parameters for people to choose mxd and folder of PDFs to compare mxdList = string.split(arcpy.GetParameterAsText(0), ";") dir = arcpy.GetParameterAsText(1) fc_path = arcpy.GetParameterAsText(2) for mapDoc in mxdList: arcpy.mapping.MapDocument(mapDoc) for lyr in m.ListLayers(mxd): if lyr.supports('DATASOURCE'): if lyr.dataSource == fc_path: max_list = [] rows = arcpy.SearchCursor(fc_path, "Sheet_ID") for row in rows: max_list.append(row.Sheet_ID) pdf_count = max(max_list) arcpy.AddMessage('Sheet count: %s'%pdf_count) else: arcpy.AddError('No layers in %s match data source'%mapDoc)
pdfDoc = arcpy.mapping.PDFDocumentOpen(path) print pdfDoc.pageCount
The pdfs are created from the one mxd. For example: Abilene has 11 sheets (data driven pages) so when that tool makes the PDFs it makes 11 PDFS. One for each sheet or Data driven page.
#Purpose: Compares SheeID field to the toal PDFs created from Data Driven Pages Program import arcpy, os, sys from os import path as p from arcpy import mapping as m #Make parameters for people to choose mxd and folder of PDFs to compare mxdList = arcpy.GetParameterAsText(0).split(';') pdf_path = arcpy.GetParameterAsText(1) fc_path = arcpy.GetParameterAsText(2) report = {} for mapDoc in mxdList: arcpy.mapping.MapDocument(mapDoc) for lyr in m.ListLayers(mxd): if lyr.supports('DATASOURCE'): if lyr.dataSource == fc_path: max_list = [] rows = arcpy.SearchCursor(fc_path, "Sheet_ID") for row in rows: max_list.append(row.Sheet_ID) pdf_count = max(max_list) arcpy.AddMessage('Sheet count: %s'%pdf_count) else: arcpy.AddError('No layers in %s match data source'%mapDoc) # List all PDF's in the pdf_path folder arcpy.env.workspace = ws = pdf_path for pdf_doc in arcpy.ListFiles('*.pdf'): if ''.join([a for a in pdf_doc.split('.')[0] if a.isalpha()]) == mapDoc.replace('_',''): pdf = p.join(ws, pdf_doc) pdf_object = arcpy.mapping.PDFDocumentOpen(pdf) page_count = pdf_object.pageCount if page_count == pdf_count: arcpy.AddMessage('%s Sheet Count matches number of pages in %s' %(mapDoc,pdf_doc)) else: report[mapDoc] = pdf_doc # Report maps that do not match up if len(report > 0): f = open(p.join(ws,'Page_Report.txt')) for k,v in report.iteritems(): f.write('%s Sheet Count does not match number of pages in %s\n\n' %(k,v)) f.close() arcpy.AddMessage('Created report for map documents and PDF\'s') else: arcpy.AddMessage('All PDF\'s have the correct amount of pages')
#Purpose: Compares SheeID field to the toal PDFs created from Data Driven Pages Program import arcpy, os, sys from os import path as p from arcpy import mapping as m #Make parameters for people to choose mxd and folder of PDFs to compare mxdList = arcpy.GetParameterAsText(0).split(';') pdf_path = arcpy.GetParameterAsText(1) fc_path = arcpy.GetParameterAsText(2) report = {} page_list = [] for mapDoc in mxdList: arcpy.mapping.MapDocument(mapDoc) for lyr in m.ListLayers(mxd): if lyr.supports('DATASOURCE'): if lyr.dataSource == fc_path: max_list = [] rows = arcpy.SearchCursor(fc_path, "Sheet_ID") for row in rows: max_list.append(row.Sheet_ID) sheet_count = max(max_list) arcpy.AddMessage('Sheet count: {0}'.format(sheet_count)) else: arcpy.AddError('No layers in %s match data source'%mapDoc) # List all PDF's in the pdf_path folder arcpy.env.workspace = ws = pdf_path for pdf_doc in arcpy.ListFiles('%s*.pdf' %mapDoc): page_list.append(''.join([i for i in pdf_doc.split('.')[0] if i.isdigit()])) page_count = max(page_list) if page_count == sheet_count: arcpy.AddMessage('%s Sheet Count matches number of pages in %s' %(mapDoc,pdf_doc)) else: report[mapDoc] = pdf_doc # Report maps that do not match up if len(report > 0): f = open(p.join(ws,'Page_Report.txt')) for k,v in report.iteritems(): f.write('%s Sheet Count does not match number of pages in %s\n\n' %(k,v)) f.close() arcpy.AddMessage('Created report for map documents and PDF\'s') else: arcpy.AddMessage('All PDF\'s have the correct amount of pages')
#Purpose: Compares SheeID field to the toal PDFs created from Data Driven Pages Program import arcpy, os, sys from os import path as p from arcpy import mapping as m #Make parameters for people to choose mxd and folder of PDFs to compare mxdList = arcpy.GetParameterAsText(0).split(';') pdf_path = arcpy.GetParameterAsText(1) fc_path = arcpy.GetParameterAsText(2) report = {} page_list = [] for mapDoc in mxdList: arcpy.AddMessage(mapDoc) mxd = arcpy.mapping.MapDocument(mapDoc) for lyr in m.ListLayers(mxd): if lyr.supports('DATASOURCE'): if lyr.dataSource == fc_path: max_list = [] rows = arcpy.SearchCursor(lyr) for row in rows: max_list.append(row.Sheet_ID) sheet_count = max(max_list) arcpy.AddMessage('Sheet count: %s'%sheet_count) else: arcpy.AddError('No layers in %s match data source'%mapDoc) # List all PDF's in the pdf_path folder arcpy.env.workspace = ws = pdf_path for pdf_doc in arcpy.ListFiles('*.pdf'): page_list.append(int(''.join([i for i in pdf_doc.split('.')[0] if i.isdigit()]))) page_count = max(page_list) if page_count == sheet_count: arcpy.AddMessage('%s Sheet Count matches number of pages in %s' %(mapDoc,pdf_doc)) else: report[mapDoc] = pdf_doc # Report maps that do not match up if len(report) > 0: f = open(p.join(ws,'Page_Report.txt')) for k,v in report.iteritems(): f.write('%s Sheet Count does not match number of pages in %s\n\n' %(k,v)) f.close() arcpy.AddMessage('Created report for map documents and PDF\'s') else: arcpy.AddMessage('All PDF\'s have the correct amount of pages')
