Steve,
Thanks for the follow up, I've done pretty close to what the example is doing and like you doesn't work. It seems most the time I pan the map it fixes itself, but if I write code to pan the map to a different location on a timeout after it loads bad still. I've tried map.reposition() and map.resize() after loading as well but no luck.
