AnsweredAssumed Answered
Use Selection of one Combobox to update the items list in another Combobox
Question asked by johnmdye on Feb 28, 2013
Latest reply on Mar 9, 2013 by johnmdye
So I have a series of Comboboxes which I created to perform a "Quick-Jump" function in which a user can select AOIs at varying geography levels, and kind of quickly drill down into a very specific AOI without having to know where it is geographically.
The Comboboxes are Major Geographic Level (MajorGeoLevel.cbx) and Minor Geographic Level (MinorGeoLevel.cbx).
Major Geographic Level contains a static items list of containing the National Extent and 8 different regions around the US. When a user selects a region, the Combobox should:
  • Perform a selection against the Regions Layer for the Region selected in the Combobox, zoom to the selected feature, turn the layer on, clear the selection and refresh the active view.
  • Enable the MinorGeoLevel.cbx and update the items contained in the MinorGeoLevel.cbx with a predefined list of Minor Geographic Levels, which correspond to the selected item in the MajorGeoLevel.cbx, unless the item selected in MajorGeoLevel.cbx is 'National'.
I am having two issues.
1. The selection from MajorGeoLevel.cbx does not seem to be doing anything. ie. When I select National...nothing happens. It doesn't even reflect in the Combobox.
2. MinorGeoLevel.cbx is not becoming enabled once a selection is made in MajorGeoLevel. Because it's not becoming enabled, I can't even tell if it's updating the item list for MinorGeoLevel.cbx either.
Here is my code:
class QuickJump_MajorGeoLevel(object):     """Implementation for QuickJump_MajorGeoLevel.cbx (ComboBox)"""     def __init__(self):         self.items = ["National", "National-Direct", "Region I", "Region II", "Region III", "Region IV", "Region V", "Region VI", "Region VII", "Region VIII"]         self.editable = False         self.enabled = True         self.dropdownWidth = 'XXXXXXXXXXXXXXXXXXXX'         self.width = 'XXXXXXXXXXXXXXXXXXXX'     def onSelChange(self, selection):         #Instantiate the current MXD as a variable         mxd = arcpy.mapping.MapDocument("Current")          #Jump to the selected MajorGeoLevel and initialize the MinorGeoLevel combobox, populated with the MinorGeoList that corresponds to the current selection         #If the current selection is 'National', jump to the NationalExtent. MinorGeoLevel.cbx and SubGeoLevel.cbx remain disabled from Initialization.         if selection == "National":             #Jump to the 'NationalExtent'             df = arcpy.mapping.ListDataFrames(mxd, "Business Analyst Map")[0]             NationalExtent = df.extent             NationalExtent.XMin, NationalExtent.YMin = -13978263.2599, -1547990.11744             NationalExtent.XMax, NationalExtent.YMax = -7429812.66299, 7011646.87809             df.extent = NationalExtent             arcpy.RefreshActiveView()          #if the current selection is National-Direct , refresh the MinorGeoLevel.cbx in the UI         elif selection == "National-Direct":             #Refresh the 'QuickJump_MinorGeoLevel' combobox which enables the combobox and updates the item list             QuickJump_MinorGeoLevel.refresh()             #Jump to the Full Extent of the National-Direct Region and Turn the layer On             for lyr in arcpy.mapping.ListLayers (mxd):              if lyr.name == "Regions_All":                 #if the layer is not currently visible, make the layer visible and refresh the Map Display Window                 if lyr.visible == False:                     lyr.visible = True                     #Establish the DataFrame and the 'Regions_All' variables                     df = arcpy.mapping.ListDataFrames(mxd, "Business Analyst Map")[0]                     Regions_All = arcpy.mapping.ListLayers(mxd, "Regions_All", df)                     #Select 'Region 1' from the 'Regions_All' layer                     arcpy.SelectLayerByAttribute_management ("Regions_All", "NEW_SELECTION", ' "REGION" = ND')                     #Zoom to the selected feature                     df.zoomToSelectedFeatures()                     #Apply a 10% Buffer to the Extent of the Zoom                     df.scale = df.scale * 1.1                     #Clear the Selection                     arcpy.SelectLayerByAttribute_management ("Regions_All", "CLEAR_SELECTION")                     #Refresh the Map Display Window                     arcpy.RefreshActiveView()          #Report an with a MessageBox if the 'Regions_All' layer is not loaded in the MXD         else:             pythonaddins.MessageBox('The layer Regions_All is not loaded in the MXD. Unable to turn layer on or jump to extent.', 'Layer not Found', 5)  class QuickJump_MinorGeoLevel(object):     """Implementation for QuickJump_MinorGeoLevel.cbx (ComboBox)"""     def __init__(self):         #Create the Predefined Item Lists, which are  initialized depending on the QuickJump_MajorGeoLevel Combobox's current selection         self.items= []         self.editable = False         self.enabled = False         self.dropdownWidth = 'WWWWWW'         self.width = 'WWWWWW'     def SelChange(self, selection):         pass     def refresh(self):         #Create the Predefined Minor Geography Item Lists, which are  implemented in the QuickJump_MinorGeoLevel Combobox depending on the QuickJump_MajorGeoLevel Combobox's current selection         ND_MinorGeoList = ["Boston", "Los Angeles", "San Francisco", "Honolulu", "Chicago", "Minneapolis/St. Paul", "New York", "Philadelphia", "Wilmington"]         RegionI_MinorGeoList["New York-Northern New Jersey-Long Island, NY-NJ-PA"]         RegionII_MinorGeoList["New York-Northern New Jersey-Long Island, NY-NJ-PA"]         RegionIII_MinorGeoList["Bridgeport-Stamford-Norwalk, CT", "Hartford West-Hartford East, CT", "New Haven-Milford,CT", "New York-Northern New Jersey-Long Island, NY-NJ-PA", "Poughkeepsie-Newburgh-Middletown, NY", "Torrington, CT", "Trenton-Ewing, NJ", "Allentown-Bethlehem-Easton, PA-NJ", "Philadelphia-Camden-Wilmington, PA-NJ-DE-MD"]         RegionIV_MinorGeoList["Baltimore-Townsend, MD", "Cambridge, MD", "Dover, DE", "Easton, MD", "Gettysburg, PA", "Lexington Park, MD", "Ocean Pines, MD", "Salisbury, MD", "Seaford, DE", "Washington-Arlington-Alexandria, DC-VA-MD-WV", "York-Hanover, PA"]         RegionV_MinorGeoList["Baltimore-Townsend, MD", "Chambersburg, PA", "Charlottesville, VA", "Culpepper, VA", "Cumberland, MD-WV", "Gettysburg, PA", "Hagerstown-Martinsburg, MD-WV", "Harrisonburg, VA", "Richmond, VA", "Staunton-Waynesboro, VA", "Washington-Arlington-Alexandria, DC, VA-MD-WV", "Winchester,VA-WV"]         RegionVI_MinorGeoList["Athens, TX", "Bonham, TX", "Dallas-Fort Worth-Arlington, TX", "Durant, OK", "Gainesville, TX", "Palestine, TX", "Paris, TX", "Sherman-Denison, TX", "Sulpher Springs, TX", "Alexandria, LA", "Baton Rouge, LA", "Crowley, LA", "DeRidder, LA", "Fort Polk South, LA", "Jennings, LA", "Lufkin, TX", "Natchez, MS-LA", "Opelousas-Eunice, LA", "Bastrop, LA", "El Dorado, AR", "Jacksonville, TX", "Longview, TX", "Magnolia, AR", "MArshall, TX", "Minden, LA", "Monroe, LA", "Mount Pleasant, TX", "Nacogdoches, TX", "Natchitoches, LA", "Ruston, LA", "Shreveport-Bossier City, LA", "Tallulah, LA", "Texarkana, TX", "Tyler, TX", "Vicksburg, MS"]         RegionVII_MinorGeoList["Baton Rouge, LA", "Bogalusa, LA", "Crowley, LA", "Gulfport-Biloxi, MS", "Hammond, LA", "Houma-Bayou Cane-Thibodaux, LA", "Jennings, LA", "Lafayette, LA", "Lakes Charles, LA", "McComb, MS", "Morgan City, LA", "New Iberia, LA", "New Orleans-Metairie-Kenner, LA", "Opelousas-Eunice, LA", "Picayune, MS", "Pierre Part, LA"]         RegionVIII_MinorGeoList["Alice, TX", "Austin-Round Rock-San Marcos, TX", "Bay City, TX", "Brenham, TX", "Brownsville-Harlingen", "College Station-Bryan, TX", "Corpus Christi, TX", "El Campo, TX", "Huntsville, TX", "Kileen-Temple-Fort Hood, TX", "Kingsville, TX", "Marble Falls, TX", "McAllen-Edinburg-Mission, TX", "Raymondville, TX", "Rio Grande City-Roma, TX", "San Antonio-New Braunfels, TX", "Victoria, TX", "Abbeville, LA", "Beaumont-Port Arthur, TX", "DeRidder, LA", "Houston-Sugar Land-Baytown, TX", "Jennings, LA", "Lake Charles, LA"]         if QuickJump_MajorGeoLevel.selection == "National-Direct":             self.enabled = True             self.items = ND_MinorGeoList
Any insight is greatly appreciated
Outcomes
