Is there a way to turn off popups for only certain layers? My app loops through the visible layers and returns a popup for each. Some of the layers only show boundaries, so I don't need anything to be created for it. the loop:function initIdentifies(map) {
idParams = new esri.tasks.IdentifyParameters();
idParams.tolerance = 5;
idParams.returnGeometry = true;
idParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_VISIBLE;
dojo.connect(map, "onClick", runIdentifies);
function runIdentifies(evt) {
var layers = dojo.map(map.layerIds, function(layerId) {
return map.getLayer(layerId);
}); //Create an array of all layers in the map
layers = dojo.filter(layers, function(layer) {
return layer.getImageUrl && layer.visible;
}); //Only dynamic layers have the getImageUrl function. Filter so you only query visible dynamic layers
var tasks = dojo.map(layers, function(layer) {
return new esri.tasks.IdentifyTask(layer.url);
}); //map each visible dynamic layer to a new identify task, using the layer url
var defTasks = dojo.map(tasks, function (task) {
return new dojo.Deferred();
}); //map each identify task to a new dojo.Deferred
var dlTasks = new dojo.DeferredList(defTasks); //And use all of these Deferreds in a DeferredList
dlTasks.then(IDResults); //chain IDResults onto your DeferredList
idParams.width = map.width;
idParams.height = map.height;
idParams.geometry = evt.mapPoint;
idParams.mapExtent = map.extent;
for (i=0;i<tasks.length;i++) { //Use 'for' instead of 'for...in' so you can sync tasks with defTasks
try {
tasks.execute(idParams, defTasks.callback, defTasks.errback); //Execute each task
} catch (e) {
console.log("Error caught");
console.log(e);
defTasks.errback(e); //If you get an error for any task, execute the errback
How I built my popups:function IDResults(r) {
var results = [];
r = dojo.filter(r, function (result) {
return r[0];
}); //filter out any failed tasks
for (i=0;i<r.length;i++) {
results = results.concat(r[1]);
results = dojo.map(results, function(result) {
var feature = result.feature;
feature.attributes.layerName = result.layerName;
if(result.layerName === 'Zoning Classifications'){
console.log(feature.attributes.NAME);
var template = new esri.dijit.PopupTemplate({
title:"Zoning",
description:"<b>Zoning:</b> {Zoning Classification} <br/> <b>Description:</b> {Zoning Description}"
feature.setInfoTemplate(template);
else if (result.layerName === 'Assisted Living Facilities'){
title:"Assisted Living Facilities",
description:"<b>Parcel ID:</b> {Parcel} <br/> <b>Applicant:</b> {BusinessApplicantName} <br/> <b>No. of Residents</b> {NbrResidents}"
else if (result.layerName === 'Family Divisions'){
title:"Family Divisions",
description:"<b>Parcel ID:</b> {Parcel} <br/> <b>Project Number:</b> {project_nbr} </br> <b>Status:</b> {Status}"
return feature;
if(results.length === 0) {
map.infoWindow.clearFeatures();
} else {
map.infoWindow.setFeatures(results);
map.infoWindow.show(idParams.geometry);
return results;
