Hi
Using esri.symbol.SimpleMarkerSymbol and esri.symbol.TextSymbol to allow users to add points and text - however if the text is set to, say, 12pt, it stays at 12 pt, even when zoomed out. Is it possible to have te equivalent setting to ArcMap's "Scale Symbol" option - so it is as if the text or point are spray painted onto the ground and get smaller as you zoom out - like any other feature?
Cheers
ACM
