When I add the Light Gray Canvas as a base map in ArcGIS Online both the Base and the Reference portions of the layer are added beneath all of the other services that I add. This includes when I use the "Add Layer from Web" function and manually add each of the two services separately the Light Gray Canvas Reference Layer ends up at the bottom of the map above only the Light Gray Canvas Base.
The "Move Up" and "Move Down" options in the "Show Contents of Map" are unavailable for the Light Gray Canvas Reference Layer.
Normally, not in ArcGIS Online, when you add the Light Gray Canvas the Base Layer is added as a Basemap and the Reference Layer is added to the top of the Legend.
Any help would be greatly appreciated.
Thanks.
Thanks.
If its a basemap, it will always be at the bottom. I was able to move the reference layer up and down, but it can depend on what content you also have in your map. For example, if you have added a shapefile into the map you cannot display a map service on top of it.
Hope that helps,
Andrew
