AnsweredAssumed Answered
Near Tool Script
Question asked by clclark on Feb 25, 2013
Latest reply on Feb 25, 2013 by Caleb1987
Okay. My script is running but it is taking for ever! The percent bar on the bottom of ArcCatalog is still at 0%, hopefully this script ends up working. In the meantime I was hoping I could post it here and see if anyone can spot some errors. Basically I feel I am not that great at python scripting and I am sure I will get an error.
# Import arcpy module
import arcpy, sys, traceback
from os import path as p
arcpy.env.workspace = r"G:\ChrisGIS\PS_Steelhead\Work"
flds = ['DIST_TYPE', 'NWIFC_ODISTTYPE']
try:
    for ws in arcpy.ListWorkspaces("*", "FileGDB"):
        arcpy.env.workspace = ws
        print '\n\nSearching in %s\n\n' %ws
        NB = arcpy.ListFeatureClasses("NB*")
NHD = arcpy.ListFeatureClasses("NHD*")
        for inputFC in NB:
   arcpy.Near_analysis(inputFC, NHD)
   print 'Near Distance Calculated For %s'%inputFC
except:
    # Get the traceback object
    tb     = sys.exc_info()[2]
    tbinfo = traceback.format_tb(tb)[0]
    pymsg = "PYTHON ERRORS:\nTraceback info:\n%s\nError Info:\n%s\n" % (tbinfo, sys.exc_info()[1])
    msgs  = "ArcPy ERRORS:\n%s\n" % arcpy.GetMessages(2)
    arcpy.AddError(pymsg)
    arcpy.AddError(msgs)
    print pymsg
    print msgs
I have over 20 GDB in one folder. In each GDB there is a NB_featureclass, and a NHD_featureclass. Inside of each GDB I am wanting to run a Near on the NB and NHD feature class.
There is maybe 200 NB objects (points) and the NHD is a stream network. I simply want to know the distance to the nearest streamline from a NB object.
Thanks in Advance!
Outcomes
