christi_nelson
How to populate a list using multiple fields from a table?
Discussion created by christi_nelson on Feb 23, 2013
Hi all,
Below is a script that creates and empty list, loops thru a parcels feature class, gets the value for each record in the 'APN_NU_1' field and populates the list with the values.  This runs perfectly.  How do I write this script to populate the list with multiple fields and their values, say 'APN_NU_1', 'ADDR_B', and 'CITY'?
import modules and define workspace
import arcpy
import os
import traceback
workspace = arcpy.env.workspace = "E:/dev/Christi/PSL/"
#Define map document
mxDoc = arcpy.mapping.MapDocument("CURRENT")
#List the first dataframe (named Layers) in the map document
df = arcpy.mapping.ListDataFrames(mxDoc, "Layers") [0]
#List first map layer (which is the parcels layer) in dataframe
parcelLayer = arcpy.mapping.ListLayers(mxDoc,"",df) [0]
#Select parcel layer by attribute and clear any previously selected features
#Set up a Search Cursor to go thru the attribute table and get row values
#Set up variable, then read the row values for 'APN_NU_1' field and populate the list
arcpy.SelectLayerByAttribute_management(parcelLayer,"CLEAR_SELECTION")
rows = arcpy.SearchCursor(parcelLayer)
stringList = []
for row in rows:
        stringList.append(row.getValue('APN_NU_1'))
Outcomes
