What are you saying, during the installation there is a step which the setup show a dialog box with a path to deploy the application. If my assumption is correct then all it needs to be done is to enclose the default path in quotes and that should take care of everything.
I do not have access to the set up package, but I iwll inform the technical support to be in the look out when installing the application.
