frank_mclean
Export Web Map and legend color oddness - ArcGIS for Server 10.1
Discussion created by frank_mclean on Feb 19, 2013
Latest reply on Feb 26, 2013 by frank_mclean
I have a geoprocessing service which exports its results as a map service.  I use this to produce a printable map via the Export Web Map utility.  The issue I'm having is the seemingly odd designation of colors for the output layer.  I've symbolized the output with the exact same layer file I use for the input (output is basically a subset of input) and the colors are completely different, though consistently (as far as I can tell) completely different, i.e. the same odd palate is used each time.
Does anyone have any clues?
Frank
Outcomes
