jbailey.spatialbridge
Why does it take so long to create a service definition?
Discussion created by jbailey.spatialbridge on Feb 19, 2013
I've created a map document in ArcMap 10.1 SP1, and from that I'm sharing it as a service definition. The data in the map document is stored on a shared drive (which happens to be on the same machine that hosts my ArcGIS Server instance). The data folder is registered with ArcGIS Server (using its UNC path). I'm saving the .sd file in the shared folder on the server.
Creating the service definition is taking forever (over 1/5 hours). Granted, the data source is fairly large, but since  it's not being copied to the server, what's taking so long to create the service definition?
Jon.
Outcomes
