Good afternoon everyone!I�??ve been trying to run the following query on 3.8 million points for a week now. I ran it 4 times with always the same result: it runs for 8+ hours and then SQLPlus idles for ever and SQL Developer tells me the query ended with an error.
STATUS Duration SQL_ID Session_id Session_serial instance_dop CPU_Time IO_Time Start_Time
DONE (ERROR) 67188 099q07k78mx7f 12 12535 1|0 3474.06 2.75 15-FEB-2013 11:06:15
create table ST_GC_SINGLEHOUSE as
select
a.idadr as featureid,
a.nocivq as housenumb,
trim(o.odogener || ' ' || o.odoparti) as prefixtype,
trim(o.odospeci) as streetname,
trim(o.odoorien) as suffixdir,
trim(m.munnom) as city,
CP.CODPOS as ZIPCODE,
sde.st_x(sde.st_transform(a.SHAPE,4269)) as LON, --epsg 4269 : NAD83
sde.st_Y(sde.st_transform(a.shape,4269)) as lat,
a.seqodo as streetid,
a.shape as shape
from
st_adresses a,
aq_odonymes o,
aq_municipalites m,
aq_cp_adresses cp
where
a.seqodo = o.seqodo
and
a.codemun = m.codemun
and
a.idadr = cp.idadr;
If you wonder why I'm using EPSG 4269 here see my previous post:http://forums.arcgis.com/threads/77998-SDE.ST_TRANSFORM-ERROR?p=274138#post274138 In the above query, ST_Adresses in stored in ESRI ST_GEOMETRY. So I ran the same query on the same 3.8 millions points but this time using SDO_Adresses stored as SDO_GEOMETRY Oracle Spatial format.All the other tables are the same and indexes are built on each single join field in both cases on top of having spatial indexes. So the same query using SDO_GEOMETRY completes successfully in 42 min 40 sec.
create table SDO_GC_SINGLEHOUSE as
select
SDO_CS.TRANSFORM(A.SHAPE,4326).SDO_POINT.X as LON,
SDO_CS.TRANSFORM(A.SHAPE,4326).SDO_POINT.Y as lat,
a.shape as shape
from
sdo_adresses a,
aq_odonymes o,
aq_municipalites m,
aq_cp_adresses cp
where
a.seqodo = o.seqodo
and
and
a.idadr = cp.idadr;
What�??s wrong with my ST_GEOMETRY query ?
