RPictures
Difference between Total_Lenght and Shape_Lenght fields
Discussion created by RPictures on Feb 18, 2013
Latest reply on Feb 22, 2013 by RPictures
Good day to everyone,
I've found some discrepancies in the attribute table of the routes when I solve the Closest Fascilitie. Network analyst writes the result into a field "Total_Lenght" (in some units, as I understand - those units that I've choosed while creating Network Dataset). When I export the Routes layer to the geodatabase, automaticly there is created field "Shape_Lenght". BUT! The value is different then in "Total_Lenght". The problem is not in the map units - they are the same that in the network dataset.
Anybody can explain what's happening with that both values? :)
Outcomes
