Parking Lot
5590
7
02-17-2013 10:38 PM
ziadfilfili
If I want to create a parking lot with plenty of parking spaces for cars in a plot
Is there any rule for this, that can be made ?
Regards,
MatthiasBuehler1
Hi !
There's no rule for this yet available, but this should be possible.
Can you post 2,3 reference images ?
m.
ziadfilfili
Those are some reference images the way i am thinking of parking lots to do.
MatthiasBuehler1
Hi !
Yes, such a rule can be created. That's not very complicated.
Are you already a little familiar with CGA ? Already did some scripting yourself ?
m.
ziadfilfili
Hey,
yes I did some scripting. I am trying to figure it out such applying it as a texture but still nthg happened.
Cuz i need to place the cars with-in the lines. Is there a way to control the number of parking spots (lines) ?
thanks for the help..
MatthiasBuehler1
Hi ..
See attached image.
0] alignScopeToGeometry(yUp, any, longest)
1] Red split.
2] Dark blue split. tricky : repetitive split !!
3] Green split.
4] Light blue split ( repetitive ).
[ATTACH=CONFIG]21940[/ATTACH]
Hope this helps.
m.
by Anonymous User
Not applicable
apologies for resurrecting such an old post, but I would like to create a similar thing. However, I am a complete novice when it comes to CGA and scripting. I have followed the tutorials but still struggle.
Your last past did not make any sense to me.
I'd be trying to recreate something like the attached image, but with white lines and the option to add 'open space' islands.
parking lot
CherylLau
A search of old Geonet posts led to the following, some which have included code:
parking garage
Parking lot and private street
Project Showcase
In general, you'll probably want to use multiple (nested) splits to divide your lot into rows and then into parking spots. Use case statements to choose whether or not to create open spaces.
split operation—CGA | Documentation
