#The log level of the application #possible values: SEVERE,WARNING,INFO,CONFIG,FINE,FINER,FINEST,OFF,ALL logLevel=SEVERE #enable/disable console logging consoleLogging=false #Collection of allowed cross-domain origins, If this property is not specified, it will default to allowing access to all domains allowedOrigins=* #Client App properties #JS API URLs jsapi.arcgis=http://172.10.1.41/arcgis_js_api/library/3.3/jsapi #jsapi.arcgis.sdk=http://help.arcgis.com/en/webapi/javascript/arcgis/ jsapi.arcgis.css=http://172.10.1.41/arcgis_js_api/library/3.3/jsapi/js/dojo/dijit/themes/tundra/tundra.css #ArcGIS.com URLs arcgis.com.map=http://www.arcgis.com/home/webmap/viewer.html arcgis.com.map.text=ArcGIS.com Map
Solved! Go to Solution.
#JS API URLs jsapi.arcgis=http://<server_name>/arcgis_js_api/library/3.3/jsapi/ jsapi.arcgis.sdk=http://<server_name>/arcgis_js_sdk/sdk/ jsapi.arcgis.css=http://<server_name>/arcgis_js_api/library/3.3/jsapi/js/dojo/dijit/themes/tundra/tundra.css
<style type="text/css"> @import "<%=jsapiArcgisCssUrl%>"; @import "<%=cpath%>/static/jsapi.css"; @import "<%=jsapiArcgisUrl%>/js/esri/css/esri.css"; </style>
Copyright (c) 2004-2011, The Dojo Foundation All Rights Reserved.
Available via Academic Free License >= 2.1 OR the modified BSD license.
see: http://dojotoolkit.org/license for details
This is an optimized version of Dojo, built for deployment and not for
development. To get sources and documentation, please visit:
//>>built
ETC......
