Pi-Hellz
List index out of range problems
Discussion created by Pi-Hellz on Feb 13, 2013
Latest reply on Feb 13, 2013 by Pi-Hellz
I have a List index out of range problems. I think that's come from my delete field operation but I'm not sure. Any ideas ???
The resulting layers of my script are what I'm suppose to have. Anyone have a solution to my problem.
    # Suppresion des champs récurents
    # Delete duplicating fields
    DropField = ("FacilityID_1;Name_1;FromBreak_1;ToBreak_1")
    arcpy.DeleteField_management(IntersectBoucle,DropField)
    outputPolygons1 = "C:\Temp\Zone_Support_mutuel_test\Test_temp\ServiceAreaV2\Intersect" + "\\" + "Intersect" + str(j)
    # Variable de la boucle
    # Loop Variable
    k = 1
    fclistBoucle = fclist[k]
    # Debut de la boucle
    # Loop start
    #for i in range(len(fclist)):
        #if k < 9 :
        looptime = time.asctime()
        print looptime
        print i
        print fclistBoucle
        print str(IntersectBoucle)
        # Intersection
        arcpy.Intersect_analysis([IntersectBoucle,fclistBoucle],OutIntersectBoucle)
        print "#### " + str(k) + "ieme intersection(Boucle) ###########"
        fieldnames4 = [f.name for f in arcpy.ListFields(OutIntersectBoucle)]
        print fieldnames4
        # Peupler les champs isSame, Supported and Supporting
        # Populate field isSame, Supported and Supporting
        arcpy.CalculateField_management(OutIntersectBoucle,"isSame","isSame( !Name!, !Name_1! )","Python_9.3",codeblock)
        arcpy.CalculateField_management(OutIntersectBoucle,"Supported","PeuplerZone ( !isSame!, !Name!)","Python_9.3",codeblock2)
        arcpy.CalculateField_management(OutIntersectBoucle,"Supporting","PeuplerZone ( !isSame!, !Name_1!)","Python_9.3",codeblock3)
        j += 1
        # Extraire les enregistrements qui respectent les conditions pour les zones soutenues et supportées
        # Extract feature that meets requirements for Supporting and Supported zones
        arcpy.CopyFeatures_management(OutIntersectBoucle, outputPolygons1)
        # Extract feature that doesn't meets requirements and needs to be Intersect again
        arcpy.MakeFeatureLayer_management(OutIntersectBoucle,IntersectBoucle,isSameQuery)
        #k += 1
        #fclistBoucle = fclist[k]
        OutIntersectBoucle = "in_memory" + "\\" + "OutIntersect" + str(j)
        k += 1
        #if k >9:
            #break
    print "L'opération d'intersection est complétée"
Here the errors I have :
ERROR: PYTHON ERRORS:
Traceback info:
  File "C:\Documents and Settings\uboiv8z\workspace\Network_Analyst\src\Zone_Support_Mutuel\ZSM_Elevation_V8_Intersect_exportV8-1.py", line 122, in <module>
Error Info:
list index out of range
ERROR: ArcPy ERRORS:
WARNING 000728: Field FID_Global,FacilityID_1 does not exist within table
Thanks you
Outcomes
