kawbin
esri.config.default.io.proxyURL not set error
Discussion created by kawbin on Feb 12, 2013
Latest reply on Feb 13, 2013 by Jian
Evening,
Was working on batch geocoding using a web UI when this error message was returned to me by my own arcgis server. Any idea what is causing it? what can be done about it? I understand that one solution to this is to install and use the proxy page. However, due to project requirement, its best i avoid using the proxy page. Is there any other alternative to solving this error?
This error only pops out when the sample address data set exceeds 13 sets. if i use smaller data sets < 14, the error will not appear and everything will function correctly.
Outcomes
