Adjust Flow Direction in Lakes. Stream grid or stream as input?
4661
02-06-2013 04:09 AM
D_D_
accodrding to "Arc Hydro Tools Tutorial (Version 2.0 - October 2011)" to process the "Adjust Flow Direction in Lakes" function I need to:
Confirm that the input for Flow Direction Grid is ???FdrSink???, Lake Polygon a lake polygon feature class (e.g. NHDWaterbody) and Stream a line feature class (e.g. NHDFlowline). The output is the Bowled Flow Direction Grid, named by default ???BowlFdr???. This default name can be overwritten.
but it can`t be done because this function requires grid data as initial to stream (grid?). So, I don`t know how to perform this tutorial further.
Best regards.
ChristineDartiguenave
There are been quite a few changes since 2.0. We are in the process of on updating the tutorials. Meanwhile your best source for the documentation is the online help for the toolbar and the toolbox. The tool now requires a stream grid input instead of stream features which were internally converted to grid by the process. In some cases, this conversion resulted in some extra "stream" cells and potential sinks. You can use as input any grid that masks the stream cells. The values of the grid cells in the stream do not matter. So you can use the stream grid or stream link grid (this one may be created by the Create Drainage Line Structures function).
Christine Dartiguenave
Esri Water Resources Team
ZacharyBenedetto
I am trying to use this tool too, but the tutorial text says to use "FdrSink" as input, while the picture above it says to use "FdrFilled." Can you clarify which is the correct input?
[ATTACH=CONFIG]30529[/ATTACH]
Thanks!
Zack
The input depends on the operations you performed on the DEM. With that tool, you adjust the flow direction grid within the lakes so that the water flows toward the closest stream feature within the lakes. You may or not have sinks in your dem you want to preserve (or fill). So the input is your flow direction grid created and adjusted, if needed, in sinks and/or streams.
