I have begun to work on a prototype of a plugin to ArcMap 10.1. It works on our computers and for some customers, but other customers get an exception.
Exception message:
[INDENT]Error HRESULT E_FAIL has been returned from a call to a COM component.[/INDENT]
Top of call stack:
[INDENT]at ESRI.ArcGIS.Geodatabase.IDataset.get_Workspace()[/INDENT]
The C# code that triggers the exception is probably
[INDENT]
IDataLayer2 dataLayer = ...
IDataset dataset = dataLayer as IDataset;
try
[INDENT] if (dataset != null
[INDENT] && dataset.Category == "Shapefile Feature Class"
&& dataset.Workspace.Type == esriWorkspaceType.esriFileSystemWorkspace)
[/INDENT]
}[/INDENT]
catch (Exception e)
[/INDENT]
So, it seems that the call to dataset.Workspace.Type throws an exception. What could cause that?
I noticed that there is a boolean method I could have called,
[INDENT]
if (dataset.Workspace.Exists())
[/INDENT]
but if I get an exception just by getting the Workspace, I assume that I would never reach the Exists() method.
And I don't see what non-existence means. Is it the same as "file not found"?
I would be grateful for any help.
