I want to create a geodatabase as workspace using python. It woks if the Geodatabase is called data.gdb. But if I change the name of the geodatabase, the FC are stored as shapefile in the external folder but not into the geodatabase
import os
import arcpy
import sys
from arcpy import env
import os.path as path
import arcpy.cartography as CA
Building = sys.argv [1]
DirOutPut = sys.argv[2]
arcpy.management.CreateFileGDB(sys.argv[2], "data_building.gdb", "CURRENT")
##With this Geodatabase name does not work. But it works with the name data.gdb, I need that the GDB has different name than data
results_gdb = os.path.join(DirOutPut + "\\"+"data_building.gdb")
arcpy.env.workspace = results_gdb
CA.SimplifyBuilding(Building ,"Building_symply", 0.5)
