No editable layers
4630
5
01-30-2013 11:53 PM
AlexKaiserlis
I have a problem editing feature classes from a arcsde database. When i try to edit the features i get the error dbo.default [mypc] No editable layers. and the warning for each layer Layer or table is not registered as versioned. Does anyone know what i have to do to fix this problem? I have set permissions for each user to have administrative control for the database.
Also when i try to Register As Versioned i get the error Failed to register as versioned. Lock requst conflicts...
JonathanQuinn
Esri Notable Contributor
What if you go to Editor drop down menu > Options > Versioning and uncheck the option to Edit a version of the database with the ability to undo and redo?
AlexKaiserlis
Ok that worked. Thanks for the help!!
LuyangRen
New Contributor III
That works for me too. Could you explain why?
Thank you!
Luyang
SH013
I just want to revive this topic, is there a way we could permanently uncheck the option to Edit a version of the database with the ability to undo and redo? Everytime I open my arcmap, the option is always checked off?
Asrujit_SenGupta
MVP Regular Contributor
Save the Map Document, with the option Unchecked and use the same MXD next time. It will remain that way...
