merge-unmerge, please help
12744
7
01-30-2013 09:23 AM
KatarinaB
I have a big problem...I have merged polygons, many of them. This was mistake in my work, so I want to know is there any possibility to unmerge it? To return my old polygons that have disapired...Is there any hope for it?:(
Thank you a lot.
RichardFairhurst
MVP Honored Contributor
Thank you a lot.
I assume you have saved the edits already, since you could use undo if you were still in the edit session where you did the merge.  If you were using SDE and had not committed the child version you were editing you could salvage the original data it it was posted in the unmerged state to a parent version.
If it is a shapefile, personal geodatabase or file geodatabase, you could only salvage your work if you had some sort of back up created by your IT department, which should be occurring if you keep your data on a network drive.  I hope that helps.
JohnSobetzer
If you are using Windows 8 and file history is enabled maybe you can find an older version.  In Windows 7 previous versions might allow the same.  I've never used either, yet, and it strikes me it might be difficult to use either with folder type entities like coverages which also have info tables, or file geodatabases.  But shapefiles with their limited files in number and sharing the same name, just different extensions, might be more feasible.
KatarinaB
Saving old files didn't work, we had some issues with our back up files. I had to work all over again 😕
thank you all for your answers!
MelanieSummers
Occasional Contributor III
If you merged features that do not share a boundary, you may be able to run the multipart to singlepart tool.
Best,
Melanie S.
KatarinaB
unfortunately, they have! thanks anyway!
K.
shanyu
Best,
Melanie S.
That is exactly what I want!
TimLane
Multipart to single part can be useful, but with my understanding you cannot specify records within a feature layer. I was looking for a solution to this same problem where I had about 5 or 6 records within my "landscaping" layer that I had merged at one point but now realize they should be separate. Multipart to single part would have ran across all of the records when I really only wanted to touch the 5 or 6. What I found to work (in arcpro 2.4.0) is the 'Explode' Tool within the Tools section of your edit tab. You might have to scroll down a few but this worked exactly how I was wanting. I hope this helps any who are still searching this thread.
