Create Mobile Map runs only as administrator - ArcMap 10.0?
678
01-30-2013 03:53 AM
nagavijayasankaran
I am having an issue with running Create Mobile Map in a non admin mode.  I can create map cache files as logged in Administrator. But, if I login as a standard user (which is where the users will log in), I get a generic error - Invalid custom tool.  If I run ArcMap as Administrator (Right click shortcut and select Run as administrator). I can successfully generate Map cache.
Can somebody please shed some light on this.
