gerlahi61
OGC compliant WMS services , Image Services
Discussion created by gerlahi61 on Jan 30, 2013
I have 2 questions concerning WMS services.
According to the documentation Image Services should be OGC compliant for WMS.
http://ags-sdi.jrc.it:6080/arcgis/help/en/index.html#//015400000411000000
I have the following problem: I created an Image service and got the capabilities which are automatically generated by a GetCapabilities Request.
If I validate the generated xml file, I see the following problems:
Unable to locate a reference to a supported schema type (DTD, W3C Schema) within this document instance.
The solution is to substitute this part
<WMS_Capabilities version="1.3.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd">
with
xsi:schemaLocation="http://www.opengis.net/wms http://schemas.opengis.net/wms/1.3.0/capabilities_1_3_0.xsd"
xmlns="http://www.opengis.net/wms">
After this correction there is another error:
<GetStyles>
        <Format>application/vnd.ogc.sld+xml</Format>
        <DCPType>
          <HTTP><Get><OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://ags-sdi.jrc.it:6080/arcgis/services/Danube_Test_IS/ImageServer/WMSServer"/></Get></HTTP>
        </DCPType>
      </GetStyles>
Element <GetStyles> is not allowed under element <Request>.
Reason: The following elements are expected at this location (see below)
<wms:GetFeatureInfo>
Error location: WMS_Capabilities / Capability / Request / GetStyles
After cutting off the GetStyles section the xml file is valid.
If I create the service as a map service the xml from the GetCapabilities Request is fine.
Is this a problem of ArcGIS Server and will it be resolved ?
___________________________________________________________
Second question:
I encountered the following problem with the map service SampleWorldCities xml from the GetCapabilities Request and also for other services. How can this be fixed ?
Value '180.000122' is not allowed for element <eastBoundLongitude>.
Reason: Value '180.000122' violates 'maxInclusive' facet value '180'.
Error location: WMS_Capabilities / Capability / Layer / EX_GeographicBoundingBox / eastBoundLongitude
Details
cvc-maxInclusive-valid.1: For type definition 'wms:longitudeType' the value '180.000122' is not numerically less than or equal to its 'maxInclusive' facet value '180'.
cvc-datatype-valid.2: The value '180.000122' is not a member of type definition 'wms:longitudeType'.
cvc-simple-type.1: For type definition 'wms:longitudeType' the string '180.000122' is not valid.
cvc-type.3.1.3: The normalized value '180.000122' is not valid with respect to the type definition 'wms:longitudeType'.
cvc-elt.5.2.1: The element <eastBoundLongitude> is not valid with respect to the actual type definition 'wms:longitudeType'.
extract of xml:
<EX_GeographicBoundingBox><westBoundLongitude>-180.000000</westBoundLongitude><eastBoundLongitude>180.000122</eastBoundLongitude><southBoundLatitude>-90.000000</southBoundLatitude><northBoundLatitude>90.000122</northBoundLatitude></EX_GeographicBoundingBox>
How can I set this automatically created values in the right way and where (in ArcMap) ?
Thanks for your help.
Hilde
Outcomes
