tt_rwth
Error "Spline with Barriers"
Discussion created by tt_rwth on Jan 30, 2013
Latest reply on Jan 30, 2013 by slynch-esristaff
ArcGIS 10 Service Pack 5
java version "1.6.0_23"
Java(TM) SE Runtime Environment (build 1.6.0_23-b05)
Java HotSpot(TM) Client VM (build 19.0-b09, mixed mode, sharing)
PATH Variables are set.
I have a problem with using the tool "Spline with Barriers". Since upgrade to Version 10 I get an error using this tool.
The console shows:
 Start Time: Wed Jan 30 11:13:33 2013
Running script SplineWithBarriers...
Spline with Barriers failed
Completed script SplineWithBarriers...
Failed to execute (SplineWithBarriers).
Failed at Wed Jan 30 11:13:36 2013 (Elapsed Time: 3,00 seconds)
I think the error causes somewhere at this point of the script: msgJMCunsuccessful.
Its between line 423 and 433.
Error Message is: gp.GetIDMessage (86167)
Is it possible that there is an error in the JMCTool.jar. I had a quick view into the MANIFEST.MF and found that there is no Main-Class and Class-Path defined?
The script worked fine in ArcGis 9.x with same files.
Best regards
Outcomes
