WFM Error Message
1524
01-23-2013 08:46 AM
MikeJohnson2
Greetings,
Has anyone seen the error"HRESULT_FAIL has been returned from a COM component" when using WFM Admininstrator to define/edit a Data Workspoace?
Any suggestions woul be very much appreciated!
Mike
NishiMishra
New Contributor III
More information is required to asses this error.
  1. Database being used
  2. ArcGIS and Workflow Manager release and version
When exactly do you see this error?
Nishi
KevinArmstrong
I am getting this error as well, but it is happening when I create a job in Workflow Manger 10.1.  I am working with SQLServer 2008 R2.  The configuration .jxl I imported when setting up this new WMX instance was from a Workflow Manager 10.0 instance.  I suspect that might have something to do with it, but I have not been able to find anything that says this should/can be a problem.  Everything I have seen online says importing .jxls from previous versions is supported.
