mcdade31
Strange Bug in my TOC/Search functionality
Discussion created by mcdade31 on Jan 23, 2013
Latest reply on Feb 25, 2013 by mcdade31
I have a strange bug in my app (best in IE).
The issue has to do with the search button and the grid that shows when it is clicked. If you hit search after the map loads, the grid appears without any issues.
However,
If you use the slider on the TOC panel to resize the map pane/TOC pane and then hit the search button, the grid does not appear (the map pane resizes to allow for the div, but the grid doesn't show) Further, if you then click on the slider the grid will appear...
I'm not getting any errors or warnings related to this so I'm not sure what is causing the bug. Any pointers or hints would be great.
Outcomes
