Can I Provide Coordinates to the Location Service?
283
01-22-2013 07:32 AM
JamesGist
I would like to spoof the location in my ap in order to demonstrate some functionality.  I would like to be able to provide coordinates to the location service in regular intervals in order to simulate moving along a path.
Is this possible?
AndyGup
James, yes if you have an app that already is using a Location Listener you can use what are called "Mock" locations. There are a few steps to follow:
1) Add this line to your manifest permissions:
<uses-permission android:name="android.permission.ACCESS_MOCK_LOCATION">
2) Make sure in your phone settings that you have checked "Allow mock locations"
3) Create and inject the mock locations:
Location mockLocation = new Location(mocLocationProvider);
mockLocation.setLatitude(-34.000);
mockLocation.setLongitude(72.000);
mockLocation.setAltitude(2000);
mockLocation.setTime(1359043067);
locationManager.setTestProviderLocation( mocLocationProvider, mockLocation);
4) To simulate movement set up a handler.postDelayed(this,<delay in ms>) and loop through an array containing your mock locations.
JamesGist
Thanks for the info Andy.  I'll give this a try in the next day or so and report back.
