AnsweredAssumed Answered
error at creating point shapefile from coordinates
Question asked by bogdanpalade on Jan 18, 2013
Latest reply on Jan 19, 2013 by bogdanpalade
Hello!
What I am trying to do here is to create a new point shapefile based on coordinates that are read from the atribute table of other shapefile. This is part of a larger script, I hope somebody can help me to overcome this problem.
the code:
outFolder = r"path to the destination folder" arcpy.env.workpace = outFolder outFC = "Reference.shp" XCoord = X YCoord = Y # X and Y are previously read from other table, if I set a print statement in the middle of the script they are:                   #X = 43.1016996631 and Y = 40.5788999672  sr = arcpy.CreateSpatialReference_management(r"path to WGS 1984.prj file") arcpy.CreateFeatureclass_management(outFolder, outFC, "POINT", "","","", sr)  cur = arcpy.InsertCursor(outFC) row = cur.newRow() pnt = arcpy.CreateObject("Point") pnt.x = XCoord pnt.y = YCoord row.shape = pnt cur.insertRow(row)  del cur, row
Well, after this, a point shapefile is indeed created but the point does not fall at the indicated coordinates (43.1016996631 and 40.5788999672) but way far away, and when I read the coordinates of the point they are something like -0.000078, -0.000078.
Do you know what may be the problem?
Thank you very much!
Outcomes
