import arcpy import re import os class Toolbox(object): def __init__(self): """Define the toolbox (the name of the toolbox is the name of the .pyt file).""" self.label = "GPS Isolator" self.alias = "GPS Isolator" # List of tool classes associated with this toolbox self.tools = [isolateGPS] class isolateGPS(object): def __init__(self): """Define the tool (tool name is the name of the class).""" self.label = "Get a track" self.description = "this will pull out one officers gps track..." self.canRunInBackground = True def getParameterInfo(self): """Define parameter definitions""" unitid = arcpy.Parameter( displayName="Unit ID", name="unitId", datatype="String", parameterType="Required", direction="Input") theDate = arcpy.Parameter( displayName="Date", name="date", datatype="Date", parameterType="Required", direction="Input") #startTime = arcpy.Parameter( #displayName="Start Time", #name="starttime", #datatype="Date", #parameterType="Optional", #direction="Input") #endTime = arcpy.Parameter( #displayName="End Time", #name="endtime", #datatype="Date", #parameterType="Optional", #direction="Input") outdir = arcpy.Parameter( displayName="Output Directory", name="outDir", datatype="Folder", parameterType="Required", direction="Input") output = arcpy.Parameter( displayName = "AVL", name = "avl", datatype = "Feature Class", parameterType = "Derived", direction = "Output") output.symbology= os.path.join(os.path.dirname(__file__), 'AVL.lyr') params = [unitid, theDate, outdir, output] return params def isLicensed(self): """Set whether tool is licensed to execute.""" return True def updateParameters(self, parameters): """Modify the values and properties of parameters before internal validation is performed. This method is called whenever a parameter has been changed.""" return def updateMessages(self, parameters): """Modify the messages created by internal validation for each tool parameter. This method is called after internal validation.""" return def execute(self, parameters, messages): def reformatDateTime(dt): s = str(dt) dtList = re.findall('..', s) return dtList[1] + '/' +dtList[2] + '/20' + dtList[0] + ' ' + dtList[3] +':' + dtList[4] +':' + dtList[5] arcpy.AddMessage('\n') arcpy.AddMessage('the unit id is: ' + parameters[0].valueAsText) arcpy.AddMessage('the Date is: ' + parameters[1].valueAsText) arcpy.AddMessage('the output directory is: ' + parameters[2].valueAsText) arcpy.AddMessage('\n') unitID = parameters[0].valueAsText theDate = parameters[1].valueAsText outdir = parameters[2].valueAsText #-------------CREATE THE FILE GEODATABASE----------------------------- gpspath = r'E:\gis\rawgps' m, d, y = theDate.split('/') if len(m) == 1: m = '0' + m if len(d) == 1: d = '0' + d goodDate = y + m + d gps = gpspath + '\\' + goodDate + '.gps' arcpy.AddMessage(gps) arcpy.env.workspace = outdir + '\\' + 'avl_' + goodDate + '_' + unitID + '.gdb' arcpy.CreateFileGDB_management (outdir, 'avl_' + goodDate + '_' + unitID + '.gdb') arcpy.CreateFeatureclass_management(outdir + '\\' +'avl_' + goodDate + '_' + unitID + '.gdb', unitID, 'POINT') arcpy.AddField_management(outdir + '\\' +'avl_' + goodDate + '_' + unitID + '.gdb\\' + unitID, 'unitid', 'TEXT') arcpy.AddField_management(outdir + '\\' +'avl_' + goodDate + '_' + unitID + '.gdb\\' + unitID, 'gpstime', 'DATE') arcpy.AddField_management(outdir + '\\' +'avl_' + goodDate + '_' + unitID + '.gdb\\' + unitID, 'xcoord', 'LONG') arcpy.AddField_management(outdir + '\\' +'avl_' + goodDate + '_' + unitID + '.gdb\\' + unitID, 'ycoord', 'LONG') arcpy.AddField_management(outdir + '\\' +'avl_' + goodDate + '_' + unitID + '.gdb\\' + unitID, 'hspeed', 'DOUBLE') arcpy.AddField_management(outdir + '\\' +'avl_' + goodDate + '_' + unitID + '.gdb\\' + unitID, 'heading', 'DOUBLE') c = arcpy.da.InsertCursor(outdir + '\\' +'avl_' + goodDate + '_' + unitID + '.gdb\\' + unitID, ('unitid', 'gpstime', 'xcoord', 'ycoord', 'hspeed', 'heading', 'SHAPE@XY')) i = 0 f = open(gps, 'r') for line in f.readlines(): i+=1 if len(line) > 40: #arcpy.AddMessage(line) if str(i).endswith('000'): arcpy.AddMessage('.....processed ' + str(i) + ' records.') sp = line.split('|') try: if sp[0] == unitID: c.insertRow((sp[0], reformatDateTime(sp[2]), int(sp[4]) +211, int(sp[5]), float(sp[7]), float(sp[9]), (float(sp[4]) +211, float(sp[5])))) except: pass f.close() del f, c parameters[3].value = outdir + '\\' + 'avl_' + goodDate + '_' + unitID + '.gdb' + '\\' + unitID return
Solved! Go to Solution.
Your insert works correctly, right? Just your layer isn't refreshed, am I reading you correctly?
# object in a list, if that's convenient, then loop through and clean up all refs: objList = [row, rows, thisDurnLocking, thatPieceOwork] for eachObj in objList: if eachObj: del eachObj
