Wondering also if anyone has seen this issue. We publish our map services (10.1) on our Dev Environment, and the symbols display correctly. However, when we re-map the MXD's to the UAT Workspaces, publish the SD's to our UAT environment - the map services (for some symbols) are incorrect.
We have checked that the required fonts (custom true type fonts) are registered on the UAT servers.
The only thing that is can tell is different between environments is that, while the alias names are identical, the physical file names are different. e.g. We have a TTF called Incidents_0.ttf (alias is AAHS Incidents Regular) on our dev machine, while on our UAT machines the TTF is Incidents.ttf (alias is AAHS Incidents Regular).
Would the SD's be referencing the physical file name rather than the alias font name?
-Anthony
