Good afternoon! I realize you guys have already figured out this particular issue, but I wondered if you could assist with my situation where a restart of the service fails to show templates other than MAP_ONLY. I've successfully registered and validated my template folder on the server and I'm able to view a custom MXD and the MAP_ONLY option. However, when I publish the service, the Export Web Map capabilities still show the only choice as MAP_ONLY (Map preview only shows this option as well). I've even had this occur when I've chosen folders with numerous MXDs.
If it's relevant, I'm running ArcGIS 10.1 SP1 and publishing to AGS 10.1 using the Flex Builder 3.5.
Any assistance is greatly appreciated!
Many thanks,
-Matt
