Thanks for the response Kelly. I was looking for a little more functionality than what is in that sample. I am looking to add in the editing toolbar as well which I took a screenshot of. I would like to use this toolbar but not the attribute inspector. The code I am using for this is as follows:
var settings = {
map: map,
templatePicker: templatePicker,
layerInfos: [{featureLayer: editableLayer}],
toolbarVisible: true,
showAttributesOnClick: false,
createOptions: {
polygonDrawTools:[esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYGON,esri.dijit.editing.Editor.CREATE_TOOL_AUTOCOMPLETE]
toolbarOptions: {
reshapeVisible: true,
cutVisible: true,
selectVisible: false
var params = {settings: settings};
var myEditor = new esri.dijit.editing.Editor(params,"editingTools");
myEditor.startup();
This seems to bring both the edit toolbar and the attribute inspector in, Is there a way to just get the edit toolbar?Here is the screenshot of the edit toolbar I currently have and need to keep.[ATTACH=CONFIG]20716[/ATTACH]If you need me to post more code just let me know I can, There is a lot of code in the app and I did not want to post more than was necessary
