babakkasraie
Select a Feature by Rectangle( Better code display)
Discussion created by babakkasraie on Jan 12, 2013
Latest reply on Jan 15, 2013 by babakkasraie
Hi
I have created a Python Tekinter GUI with a listbox to show the map layers and some button widgets.
I have to bind a "Select Features by Rectangle" function to the "Select Feature button "Button 1" to be able to select some parts of a layer which is inside or intersect with rectangle.
My Problem
If I wanted to use "Select a Layer by Location", it would be easy, but for "Select Features by Rectangle" tool I couldn't find a Python function. I may do three things.
1. Use the Python function for it.
2. Write codes to create a tracker rectangle on the map.
3. Find a way to turn the tool on in ArcMAP by Python codes and use it on the map.
I tried all of these ways but I was not successful.
I appreciate it, if somebody finds a solution for this question.
Following this message you can see my script. It works with any maps. You need to add it as a tool in ArcMap to read the current map.
Best Regards
Babak Kasraei
# Import modules
import sys,os,math,string,arcpy
# Import Tkinter modules
from Tkinter import *
import tkMessageBox
# This class will create a tekinter GUI with widgets
class ScrolledList(Frame):
    def __init__(self, options, parent=None):
        Frame.__init__(self, parent)
        self.pack(expand=YES, fill=BOTH)
        self.myParent=self
        sbar = Scrollbar(self)
        # This button is for exit
        self.button5 = Button(self, text="exit",background="gray")
        self.button5.pack(side=BOTTOM, padx=100, pady=10)
        self.button5.bind("<Button-1>", self.button5Click)
        # This button will show only the selected features
        self.button3 = Button(self, text=" Show only Selected features",background="yellow")
        self.button3.pack(side = BOTTOM, padx=100, pady=10)
        # This button will show all features
        self.button4 = Button(self, text=" Show All Features", background="BROWN")
        self.button4.pack(side=BOTTOM, padx=100,pady=10)
        # This button will clear selection
        self.button2 = Button(self, text=" Clear selection", background="red")
        self.button2.pack(side=BOTTOM, padx=100, pady=10)
        # This button will pick features with drawing a rectangle on the map view
        self.button1 = Button(self, text=" Pick Features",background="green")
        self.button1.pack(side = BOTTOM, padx=100, pady=10)
        self.button1.bind("<Button-1>", self.button1Click)
        # This listBox will show the contents of TOC and map layers
        list = Listbox(self, relief=SUNKEN)
        sbar.config(command=list.yview)
        list.config(yscrollcommand=sbar.set)
        sbar.pack(side=RIGHT, fill=Y)
        list.pack(side=LEFT, expand=YES, fill=BOTH)
        # Read from current map
        mxd=arcpy.mapping.MapDocument("CURRENT")
        options = arcpy.mapping.ListLayers(mxd)
        # This loop will go through each item in the TOC to list them
        count = 0
        for label in options:
            list.insert(count, label)
            count += 1
        list.bind('<Double-1>', self.handleList)
        self.listbox = list
        # This function will create a selection
    def handleList(self, event):
        index = self.listbox.curselection()
        label = self.listbox.get(index)
        self.runCommand(label)
        # This function will add a label to the Tekinter GUI to show what is selected
    def runCommand(self, selection):
        Label(text="You selected : "+selection).pack(side=BOTTOM,padx=10,pady=10)
        # This function will choose some part of a layer using a rectangle
    def button1Click(self, selection):
        # Local variables:
        layer = label
        # Process: Select Layer By Location
        arcpy.SelectLayerByLocation_management(layer, "", "", "", "NEW_SELECTION")
        # This function will close the GUI
    def button5Click(self, event):
        root.destroy()
root = Tk()
# Title of the tekinter
root.title('Theme Management')
# Label of the listbox
Label(text="Select and Unselect TOC features").pack(side=TOP,padx=10,pady=10)
options = map((lambda x: str(x)), range(20))
ScrolledList(options).mainloop()
The most important part for this question is using button one by which I have to draw a rectangle on the current map and select parts of it as follows.
        # Local variables:
        layer = label
Outcomes
